dark line on copy on KM-2560
  • jafari hs
    i got problem on kyocera KM-2560 when i using copier with ADF the dark line is coming on copy, am already clean narrow glass,change it (that glass), done some adjustment in ADF but problem still continue pleas help me guys!!
  • Aneurysm
    Administrator
    • Jan 2005
    • 1092
    Welcome to Copytechnet.com, we look forward to your participation.
    • JustManuals
      • Jan 2006
      • 9838
      Re: dark line on copy on KM-2560
      Paul@justmanuals.com
        • 23010
        When you changed the glass, did the line move?
        I'm going to make four assumptions:
        1) the line did move temporarily.
        2) the line does not continue all the way to the edge of the paper.
        3) the line does not appear when you copy from the copyboard glass.
        4) the line is in the feed direction.
        That slit glass can get dirty again and again and again. Many times a day. As long as you're feeding through documents that have something that can rub off (like wet ink or pencil or whiteout) the glass can get dirty again. My suggestion is to place the slit glass over white paper so that you can see the ink that needs to be cleaned off. Use alcohol, or something else stronger than glass cleaner.
        If one of my assumptions is wrong please clarify, so I can qualify my answer. =^..^=
        • jafari hs
          no that line is not like pensil or something drawing but is like shadow and its wide! and its not move always comes middle!
            • 23010
            What about the other three assumptions? How about a sample/scan. =^..^=
            • nmfaxman
              • 1702
              Take off the slit glass and blow real hard into the optics from front to back a few times.
              Don't use canned air and don't spit.
              Canned air can leave a deposit that the CCD will pick up.
              Any spit will make it worse.
              If that doesn't work, call a tech.
