Re: Windows Print doesn't Staple
Another codes in case you need it. This can be defaulted to 0 if U021 has been selected or new board is installed.
11 - Utax
12 - Olivetti
if that helps
I wonder have you selected the finisher manually?
Also may not hurt to check on Priner Menu (on Copier) the Emulation for Network try Auto(KPDL) with Alternative PCL6
11 - Utax
12 - Olivetti
if that helps
