FS-C8020 MFP
  • madas
    • Aug 2008
    • 313
    FS-C8020 MFP
    Hi All,
    Has anyone had a reoccuring issue with the registration on these m/c's? brief outline. the rego drifted out several month's ago way off the chart. (10kish prints) and we replaced the secondry transfer roller as per bulletin and updated f/w and followed the flow chart on the bulletin. after a few hour's we got the charts to line up. Now the same fault has arisen and I have ordered a new transfer belt as per another bulletin, but I spent an hour and a half just to get the Magenta to come close to it's alignment but not quite there. gave up at that point as there is obviously something not quite right, hence this post in the hope someone may have seen this and found the cure just incase the belt dosent do the trick.
    cheers
    Madas
  • JustManuals
    • Jan 2006
    • 9838
    Re: FS-C8020 MFP
    Paul@justmanuals.com
    • madas
      • Aug 2008
      • 313
      Re: FS-C8020 MFP
      update....It turned out to be the lasers causing the problem. I replaced the set to be sure. the chart took only 3 adjustments from way off the edge to correct alignment in the centre. Before replacement it would take dozens of adjustments and then still not quite make it to the middle.
      hope this helps.
      madas
        • 23003
        Re: FS-C8020 MFP
        In case it comes back, there is new firmware to address color registration issues. It just came out a few weeks ago. Just so ya know.
        • madas
          • Aug 2008
          • 313
          Re: FS-C8020 MFP
          cheers Blackcat,
