CS-4550ci - Scan issues
  • monstott2010
    • Jun 2025
    scanning to PDF working fine, scanning to JPEG is distorted when it gets to the PC. Tried Scan and Print option, print size correct, but the JPEG is stretched out.
  • copymech
    • Sep 2011
    • 196
    Re: CS-4550ci - Scan issues
    Just curious, whats happens if you scan to mailbox and print from there? Do the jpgs look distorted on the computer screen or just after being printed?
    • monstott2010
      printing prints off the image as it was scanned, distorted. Image shows distorted on thumbnail, in the image viewer and on prints. Using scan and print option when scanning will print correct image, anything once scanned is distorted.
        • 22999
        Well it's got to be an image processing problem for sure. I'd start be re-loading or upgrading the firmware. Next you have the image processing section starting at the CCD & SHD-PWB.
        Just out of curiosity, is the scan to email, SMB or FTP? And have you tried other options? =^..^=
        • monstott2010
          The problem seems to not affect any copying... only tested with SMB, email and FTP not configured. Have firmware ready to install, was going to go back today to reload, however, wanted to test on another machine in our office only to find that our machine has the JPEG option greyed out and not accessable. I did reload firmware on ours with no change, not sure why it is not available
          • monstott2010
            RESOLVED!! User had changed default DPI settings to 200x100, changed to 200x200 (customer wanted to have as low as possible) and tested ok.
              • 22999
              Congratulations.
              I think you'll find that the JPEG being grayed out is because JPEG is available for color scanning only. Select color scan and JPEG will become available. You may also be limited to 300x300 resolution. Additional memory is required for higher resolutions (depending on the model, of course).
              • faihasan
                You should have tried with resulation 300x300 or 200x200.
