Kyocera Taskalfa Screen Capture tool
  • Francky59
    [Misc] Kyocera Taskalfa Screen Capture tool
    Hello All,
    I would like to know if it exists (and logically, it must exists) a tool to
    do some screen capture of a Kyocera taskalfa (3500ci or 3050i for example) control panel ?
    May be it's a tips in the kyocera taskalfa local website or a tool or a way to do snapshot directly into a usb key
    or something in the maintenance mode ? don't know...
    I need this to do some snapshots to create my own user guide for final users and it seems there is
    nothing like this on the Kyocera Website.
    Regards
    Francky
  • Venom
    Technical/IT Support
    • Nov 2009
    • 765
    Re: Kyocera Taskalfa Screen Capture tool
    Just use a digital camera
    IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
      • 23007
      The users manual has great photographs of the various screens. When I've had to do this task, I'd use those pix. If you need a screen that is slightly different, I've edited the pix in Paint to add or subtract buttons, etc.
      Those were the days, when I had the time to work on things like this. =^..^=
      • Francky59
        What a cardboard solution !!!!
        it's not a solution. I try to use the second purpose. Doing some snapshots of the user manual
        but there is some snapshots capture i can't find, so....
        if someone has a tool.... Thanks
          • 23007
          ... cardboard?
          There a panel simulator program for the KM-5035 and KM-500ci, but not every model. The "Taskalfa" designation includes pretty much every machine in the last 3 years. Can you be a little more specific? =^..^=
          • Francky59
            ... cardboard?
            Yes, the models are 3050CI, 3500i, ...
            Thanks for your answer
