mita print source Ai 3010
  • mkopoiuy
    • Mar 2008
    • 54
    mita print source Ai3010
    1.
    c730 is showing when I turn m/c on and if I open and close the front cover then goes ready to copy.
    2. Second question. If I connect finisher, m/c is showing join finisher. Do i have to do something simulation.
    I will appreciate who can give me advice above questions.
    won kim
  • 10871087
    • Jan 2005
    • 1062
    The C730 is a Broken external temperature thermistor wire - The input voltage is above 4.5 V (230 bits). Take a look at the attached page from the book.
    The finisher problem is probably a broken interlock switch on the finisher. Do you have the mounting bracket on the side of the copier exit area that actuates the interlock switch?
    • mkopoiuy
      • Mar 2008
      • 54
      thank you!
      That is more than enough.
      It is helpful for me.
      Thank you very much.
      won kim
