kyocera fs-2126 firmware update
  • sderycke
    • Sep 2025
    having trouble updating firmware. i'am using a 2gb usb stick & following directions according to manual. any help would be greatly appreciated.
  • copyguy1
    • Jul 2011
    • 142
    Re: kyocera fs-2126 firmware update
    Are you useing the very latest firmware. if so there is a tech bulletin you need to read. If not make sure you have the firmware on the root of the drive. You may want to try adifferent usb stick good luck
    • Eric1968
      • 2458
      Use another stick. Some sticks can not be pushed in the machine far enough.
