Re: kyocera fs-2126 firmware update
Use another stick. Some sticks can not be pushed in the machine far enough.
Are you useing the very latest firmware. if so there is a tech bulletin you need to read. If not make sure you have the firmware on the root of the drive. You may want to try adifferent usb stick good luckLeave a comment:
having trouble updating firmware. i'am using a 2gb usb stick & following directions according to manual. any help would be greatly appreciated.Tags: None
