Jamming consistantly on duplex only. Have replaced Duplex clutch and sensor but no help?
Jam code 61 on a Copystar 520i
Re: Jam code 61 on a Copystar 520i
I bet it only does it from the LCT...use 2 springs instead of 1 on the vertical feed idler rollers on the door, install the F3 spacers under vertical feed switchesIBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
