Need firmware for KM-2050. Anyone know where I can get?
  • roveer
    My KM-2050 won't go past the KM logo. I'm told that re-loading the firmware will fix it. Does anyone know where I can find the firmware?
    Thanks,
    Roveer
  • leroyal
    Expert on The Obsolete
    • Sep 2007
    • 156
    Thanks,
    Roveer
    KMACONNECT.COM (or call an authorized dealer to send a technician out, if you are an end user)
    I know what I know better than anyone else knows what I know.
    • 10871087
      • Jan 2005
      • 1062
      Check to see if one of the keys on your op panel is stuck down. Press them all one at a time and make sure they each have a good click. A grain of crap can get stuck between the key and the op panel frame and cause the key to stick down. I have seen this cause the same symptom you are getting. If that's not the issue you should follow Leroyal's advice from the first reply.
