Urgent please: Kyocera Km 4050
  • smartkid4pc
    • Aug 2025
    [Error Code] Urgent please: Kyocera Km 4050
    Hello, I have got this error code c2250 on a kyocera Km 4050. I turn the copier off and allowed to cool, but same error code keeps coming back.
    What is the possible solution?
    Thanks in advance
  • totoro
    • 568
    Re: Urgent please: Kyocera Km 4050
    Replace the main charge assembly.
    Totoro
    • smartkid4pc
      Where is it located in the copier?
      • JustManuals
        • Jan 2006
        • 9838
        Paul@justmanuals.com
        • JSC
          Gimp
          • Dec 2006
          • 618
          You will find a main charger in roughly the same place in all copiers, if you don't know where that is then you need to pay for a tech to do it or to show you, before you make things worse. Or you could download the service and parts manuals from Paul's site......once you have paid for them obviously
          The gene pool could use a little chlorine.
          • Kidaver
            Ghoulscout
            • Apr 2011
            • 912
            I'd bet good money the cleaning pad has popped off the auger in the grid and causing the motor to hang up....take the above techs' advice and call a tech to fix it....you'd only cause more damage trying to fix this not knowing what you are doing.
            "In a cruel and evil world, being cynical can allow you to get some entertainment out of it."
            • RRodgers
              • Jun 2009
              • 1947
              Good luck.
