Kyeocera Fs1016 Jamming problem
  • sweet.persona
    Engineer
    • Nov 2009
    • 414
    [Jamming] Kyeocera Fs1016 Jamming problem
    Hi to all i have weired JAMMING problem in kyeocera fs1016 , when i start copying the paper does't get out completley , about 5cm from the paper stays on the copier !! i cleaned all the sensors in the DC PCB and i cleaned all parts in the right side but to no avail!! can anyone solve this!!THANK U IN ADVANCE
    A GREAT PLACE TO WORK - A GREAT PLACE TO GROW!
    DAMENE ABDEL AZIZ
    DJELFA
    • 22999
    Re: Kyeocera Fs1016 Jamming problem
    Jam code? =^..^=
    • sweet.persona
      Engineer
      • Nov 2009
      • 414
      How to know the JAM code!!!!!! Thank u in advance.
      DAMENE ABDEL AZIZ
      DJELFA
        • 22999
        I can only recommend what a professional technician should do:
        1) Buy a manual.
        2) Read the manual. Look up jam code.
        3) Try something to fix the problem, ... anything.
        4) Start a thread to ask for help.
        It sounds as though you skipped ahead to #4.
        • sweet.persona
          Engineer
          • Nov 2009
          • 414
          Hello Dear friend Teckat
          i have learned all the Manual But there is No Table of Jam code in it!!!!!
          if u understand my problem u may explain the solution .
          thanks in advance
          DAMENE ABDEL AZIZ
          DJELFA
            • 22999
            I don't think this model is sold in the US. The model number does not cross reference to anything I recognize. It shows only a 220v power source.
            And I doubt that I can read whatever language your manual is written in.
            Just for kicks, try sending the following PreScribe command:
            !R! KCFG"ELOG";EXIT;
            or this command may add an event log to the reports menu:
            !R! FRPO I1,1; EXIT;
            • kyogenius
              • Jul 2012
              • 136
              did this problem start when you removed fuser unit or power supply pcb, if yes check if the exit sensor switch arm is sitting on home position
              failure is not an option !
              • sweet.persona
                Engineer
                • Nov 2009
                • 414
                exit sensor is too Okay ! but the problem still Not resolved!
                any idea
                DAMENE ABDEL AZIZ
                DJELFA
                • Venom
                  Technical/IT Support
                  • Nov 2009
                  • 765
                  My guess is paper size is set wrong for tray but you have given no information. Were you able to print an event log as Blackcat suggested?
                  IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
                  • skibum
                    Independent Service Tech
                    • 231
                    The FS-1016mfp was definitely sold in the US. First check paper size settings and then if all is ok then try a page through the by pass. Check registration/timing sensor and exit sensor. Good luck, Jerry
