Secret Service Code on Kyocera
  • Microtechs
    • Jul 2025
    [Misc] Secret Service Code on Kyocera
    Hi Techs,
    Anyone able to provide the secret service mode code on the new Kyocera Taskalfa range?
    I know the 1087 one works ok. But I'm talking about the secret code.
    Cheers
  • kyogenius
    • Jul 2012
    • 136
    Re: Secret Service Code on Kyocera
    wat exactly do you want this secret code for, never heard of secret code on kyo machines, are you talking of copier management code for all kyo machines or what
    failure is not an option !
    • Montana Tech
      • Sep 2007
      • 20
      You mean the engineering access code ? No, you can't have it.
      Did I have a dream, or did the dream have me?
      Kyocera-Mita/Konica-Minolta/Ricoh-Lanier
      HP/Lexmark/etc etc etc
      • minoltaed
        • Aug 2009
        • 44
        30363036 but they disabled it.Used to be able to clear the main count with that secret password.
        • kingpd@businessprints.net
          • 921
          Why would they want anybody to ever be able to do that through the use of a code?
          Makes me leary now, what models and what other brands can this possibly be done to through some for of super secret code?
          How will one ever know the true condition of a machine if it's a low count machine?...
          • Larryo
            • Jul 2012
            • 18
            Every manufacturer has a "secret" code. Ever have to have the tech rep come out when a machine totally crashes and have them put the copy count back in? That's how they do it. No big secret, just have to know the log in sequence. Kyocera used to be 3036 3036 but it has changed on the new stuff. Ricoh has one, Sharp, Canon, everyone. If you are in this business long enough you get to know them.
            • habik
              • 2013
              Each new series that comes out have a new code.
              That is why 3036 or 0044 or 8453 or 7520 or 18__ work only on individual machines!
              heehe what a way to plug my self in
              Firmwares HERE
              • banginbishop
                grumpy old git
                • Oct 2007
                • 894
                the only time "secret codes" were used in my old company in the 90's were for clocking a meter reading or altering the toner supply on sharp copiers (parsia toner!) - so nothing good can come of it. there called secret codes for a reason to stop mere mortals fucking them up or doing something dodgy.
                Incontinentia Buttocks
                • JustManuals
                  • Jan 2006
                  • 9838
                  If we told you, we'd have to kill you too.
                  • patrcass
                    • Feb 2012
                    • 13
                    its 06141010
                    • 10871087
                      • Jan 2005
                      • 1062
                      I think you can use 41234123 on a DC-5090 to get to the fuser temp adjustment.
                      • Microtechs
                        Just to answer the question of why, because im a Tech.
                        If you potentially have a tool at your disposal for testing or in the case I had where the machine required a full reset, due to the machine completely locking up.
                        In the end just had to leave the client down for 2 days while the Kyocera Rep came out and unlocked the machine for us.
                        Wonderful impression for a new client.
                        Normal 1087 codes did not reset it or firmware updates.
                        The secret code was the "fix".
                        • taskalfaman
                          • Nov 2009
                          • 137
                          pirates.
                          My opinion => if you are not KYO- Certified why should you need "secret codes". Some things should be kept inside Compagnies.
                          please put it off the forum.
                          • martebs
                            Originally posted by patrcass
                            its 06141010
                            30363036 and 06141010 don't work on my machine.
                            I have and TA 3005ci.
                            any idea ?
                            • kyove
                              • Apr 2015
                              • 62
                              Hi Guys,
                              Anyone knows the secret code for TASKalfa 2551ci?
                              And for the new Iris series (2552ci/3252ci/4052ci/5052ci/6052ci) ?
                              Thank you in advance,
                              Kyove
