Secret Service Code on Kyocera
  • marks
    • May 2017
    • 3
    #16
    Re: Secret Service Code on Kyocera
    Originally posted by martebs
    30363036 and 06141010 don't work on my machine.
    I have and TA 3005ci.
    any idea ?
    TA2550ci is 2500 use the first 2 numbers in the model then add 00
    • recepgultekin
      #17
      Originally posted by patrcass
      its 06141010
      Hi, how it reset M3550idn counter. Please help me i very religion.
      • banginbishop
        grumpy old git
        • Oct 2007
        • 894
        #18
        Remove tha back panel, remove the largest circuit board you see, desolder all the components & add a paper clip in the spaces. Works every time😏
        Incontinentia Buttocks
        • recepgultekin
          #19
          I can not get into the reset menu. How would it be useful to put the clips?
          • tonerleak
            • Mar 2012
            • 67
            #20
            All I can say after that last post is OMG and WTF!
            • recepgultekin
              #21
              have it who know counter reset?
              • The_Murph
                • 96
                #22
                I think the usefulness of the clips is that it provides a redundant circuit to ensure proper connectivity between pwb's. Use many clips, that will ensure that the reset menu is displayed.
                good luck
                If you phrase your inquiry properly, you will get the answers you seek...
                Good Luck ... You'll need it! HAHAHA!
                ~Big Dan~
                • dickierock
                  • 252
                  #23
                  I could do with this secret code specifically for TaskAlFA 5500i, but for genuine reasons if anybody in the know would p.m. me.
                  Thing is I have a 5500i with 250K prints that the counter has magically gone to zero!. I want to re-instate the correct count.
                  Cheers!
                  • oneoldtech
                    • Feb 2018
                    • 2
                    #24
                    rep had to come to a machine throwing codes. he used secret code to reset and all worked. WE have to wait on them.
                    • kjg
                      • Mar 2009
                      • 111
                      #25
                      I have to admit - I tried the paperclip fix about 3 months ago. It took days to de-solder all the tiny components and replace with various sized paperclips. I may have suffered some brain damage from all the solder smoke....
                      Well, when I got finished and I powered the unit up- It booted to a very creepy laugh. Then - all my outside sprinklers came on and my M3550 started playing country music! Delta Dawn I believe.
                      This totally freaked me out so I pulled the plug and I have not plugged it back in since. (interestingly it DID reset the page counter).
                      Yes- I think I am the cause of the Alexa laugh because it was in the news just days after this happened.
                      Now what did I learn from this? I never try to reset counters. It does bad things and gives me nightmares.
                      • habik
                        • 2013
                        #26
                        I am crying...ROFL
                        Sent from portable device using fast cheapset!
                        Firmwares HERE
                        • teconcopier
                          • Mar 2013
                          • 15
                          #27
                          its 06141010
                          whats is the secrect code for latest ecosys m2040n and taskalfa 3011i machine plz give me sir
                          click here
                            not much of a tech are you?
                              • 30202
                              #29
                              906 is reset
