error code c6050 on km 1635
  • kyogenius
    • Jul 2012
    • 136
    hi
    this km1635 gives me c 6050 all the time, if you reset it with u 163 it clears but repeatedly appears, on this machine, i hv changed fuser unit but still its still coming back, sometimes it shows c6000, or c6400 all to do with fuser unit, could it be the firmware that needs upgrading,if yes hw can i get it please help
    failure is not an option !
    • 23006
    Re: error code c6050 on km 1635
    Take a look at the power, specifically ground to neutral. Obviously the power quality analyzer will provide better data, but the VOM will give you a place to start. Especially with zero-cross errors it's usually power. =^..^=
    • kyogenius
      • Jul 2012
      • 136
      ok will try that monday and will update you, thanks once again
      • JustManuals
        • Jan 2006
        • 9838
        Paul@justmanuals.com
        • vj200729
          print mate
          • 81
          may be heater thermister touching heatroller aluminium sice teflon coating damaged
          • kyogenius
            • Jul 2012
            • 136
            its a new fuser unit mate
