Bringing fax from 33.6 to 14.4 on CS2560
  • MHeon71
    • Oct 2008
    • 489
    I have a CS2560 where they were having fax issues to one location and I lowered the speed from 33.6 to 14.4 on there programmed 1 touch. Is there a way to default the transmission from 33.6 to 14.4 on all faxes.
    Any help would be appreciated.
    • 23002
    Re: Bringing fax from 33.6 to 14.4 on CS2560
    Simulation U630 should do what you want. =^..^=
    • MHeon71
      • Oct 2008
      • 489
      Thanks for your help. That is did not appear to do the trick. I gave them a work around and I will continue to research.
      • B0265
        • Jan 2007
        • 718
        You can disable the v.34 protocol in U633.
        • MHeon71
          • Oct 2008
          • 489
          Thanks, I will try that.
