km 6030 light copies
  • ringling1
    • Aug 2011
    • 33
    we have a km 6030 that has intermitant light copies. in order to get the copy quality where it needs to be, the dv bias needs to be set to 155(default is 117). we have tried different dv units with no change in symptom. any ideas? thanx
    • 23010
    Re: km 6030 light copies
    I've got three possibilities for you, and they're all related to charge loss:
    1) Worn transfer section bearings. Rebuild or replace transfer section. Replace the idler roller (302FB16450) and bearings (G3001360). When rebuilding, also examine other bearings (63520170, 27505290) and ground contact (302FB16111).
    2) Worn through developer bias terminal. Replace the developing bias contact (302FB08481). Do not lubricate. Run it dry.
    3) The mylar is worn through on the rear transfer guide (located between the transfer assy and the fuser. Replace rear transfer guide (302FB94170).
    All three situations produce almost identical quality problems. =^..^=
    • ringling1
      • Aug 2011
      • 33
      thank you, will check it out
      • ringling1
        • Aug 2011
        • 33
        where is the developing bias contact located? i cant find it in the parts manual. thanx
        • Zackuth
          • Aug 2009
          • 448
          I would look at the charge grid too. Make sure it is firmly in place and both clips are locking it down.
          If at first you don't succeed, redefine success
            • 23010
            The developing bias contact is inside the back of the imaging drawer, connecting the end of the mag roller to a contact on the rear frame. You are correct. It is not in the parts manual. A bulletin was released with part numbers of individual pieces of the imaging drawer.
            If I were you I'd remove the developing unit, and look to the spot where the end of the mag roller might touch.
            Do I have a photo to attach? Oh yes ...
            Hopefully your developer bias contact does not look like this. =^..^=
