hi, i have a creasing issue on a3 paper, tried different stock, upgraded firmware and it is a brand new fuser!! help
TASKalfa 4550ci creasing a3 paper
Re: TASKalfa 4550ci creasing a3 paper
Have you tried it from all paper sources to see if it is related to specific tray?IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications -
JoeNeill
Is print underneath or on top of the creases in the paper?IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ CertificationsComment
JoeNeill
It's a fuser issue, if you jam paper single sided pre fuser, there is no creaseComment
Paul@justmanuals.com
havent changed a fuser on these yet but was this the original fault you were called out for? and with the new fuser (cant remember if this right) but do you have to put the pressure back on when you install the new fuser? - most fusers have the pressure taken off to stop flat spots in storage.Comment
hardalf
Hi,
sounds like paper feed unit to blame. might be worth checking Tech Note B213 about the changes made to the PFU. creasing on A3 is specifically mentioned.
let me know if you need a copy.Comment
