TASKalfa 4550ci creasing a3 paper
  • JoeNeill
    [Misc] TASKalfa 4550ci creasing a3 paper
    hi, i have a creasing issue on a3 paper, tried different stock, upgraded firmware and it is a brand new fuser!! help
  • Venom
    Technical/IT Support
    • Nov 2009
    • 765
    Re: TASKalfa 4550ci creasing a3 paper
    Have you tried it from all paper sources to see if it is related to specific tray?
    IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
    • JoeNeill
      Yes all 4 sources the same, set plain paper type to mode 2 and this helped but didn't cure!!
      • Venom
        • Nov 2009
        • 765
        Is print underneath or on top of the creases in the paper?
        • JoeNeill
          It's a fuser issue, if you jam paper single sided pre fuser, there is no crease
          • JustManuals
            • Jan 2006
            • 9838
            Paul@justmanuals.com
            • banginbishop
              grumpy old git
              • Oct 2007
              • 894
              havent changed a fuser on these yet but was this the original fault you were called out for? and with the new fuser (cant remember if this right) but do you have to put the pressure back on when you install the new fuser? - most fusers have the pressure taken off to stop flat spots in storage.
              Incontinentia Buttocks
              • hardalf
                sounds like paper feed unit to blame. might be worth checking Tech Note B213 about the changes made to the PFU. creasing on A3 is specifically mentioned.
                let me know if you need a copy.
