CS-C3225E Print Issues
  • monstott2010
    • May 2025
    Off lease machine recently refurbished, tested and placed at another customer site. New customer originally set up with universal print drivers, all formating was fine but ran into issues with fonts not printing correctly. Drivers were changed out to use the KX drivers, font issue resolved, however now having formating issues.....
    Issue #1)User is printing a page of ads (for a newspaper layout) that is printing tiled over 3 sheets of 11x17, page one ok, page two slightly larger side to side, page 3 slightly larger than page 2. Lining up centered on the image, each next image is 1-2 mm larger than the previous page.
    Issue #2)On same ad page, on the bottom of the page, some of the items are left off of the printed image
    Attempted to print using different emulation settings with no apparent change. Customer is printing from QuarkXPress (not sure of exact version). Any suggestions?
    • 22930
    Re: CS-C3225E Print Issues
    How about converting the Quark output to PDF before printing, i.e. CutePDF?
    You could also try changing print emulation.
    Advanced print functions have a nasty way of over-riding other settings, like zoom for example.
    I've struggled with similar issues with Microsoft Publisher. I got lucky in finding a downgrade driver version that solved my format problem. And no other format issues came up. Just a thought. =^..^=
    • Venom
      Technical/IT Support
      • Nov 2009
      • 765
      In the print driver try each emulation and see if one corrects your issue. XL, PCL5, KPDL
      IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
