TASKalfa5500i Duplex Jamming
  • EDSNOW
    • 184
    [Jamming] TASKalfa5500i Duplex Jamming
    Has anyone hadto change out a conveying unit on this model of machine due to jamming?
    I have a machine located several hundred miles away and have to try a new conveying unit as based on the technical support and
    jam codes as well as the trouble shooting guide.
    I had to replace the exit / eject unit that sits above the fuser due to binding of the guides over time from the fuser heat and also the fuser itself due to clicking noise.
    From what I can see I will have to switch over some covers and the multi-purpose bypass tray from the old conveying unit to the nw one.
    Seems straight forward but I always respect second opinions if anyone else has had this kind of problem.
    Firmware is up to date and single sheet output works just fine.
    Any input greatly accepted and appreciated.
  • JustManuals
    • Jan 2006
    • 9838
    Re: TASKalfa5500i Duplex Jamming
    Paul@justmanuals.com
      • 23007
      Historically it's been the bridge units that have been the biggest headache. Dog-eared corners and paper jams galore. Personally I have not experienced any of these jamming problems but I've watched numerous posts on the topic.
      Let us know how it goes. =^..^=
      • Venom
        Technical/IT Support
        • Nov 2009
        • 765
        The gates in the exit unit can stick on the early ones, their was a mylar kit that basically moved the end plate out further so the gate had more play. They did change the design of the gates to be a little shorter. The ticking in the fuser was remidied by adding tapping screws to the brackets on the heat roller bearings (actually was a bulletin for that). The conveyance unit has caused a bit of problems on some, the upper duplex clutch failing and the wire tie straps being too tight.
        IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
        • Venom
          • Nov 2009
          • 765
          Have seen the folded corner issue and resolved by adding mylar extensions to the gate in the attachment kit.
