Copy quality problem on TA 300ci - 250ci
  • kaborwen
    • Feb 2010
    • 146
    Hi all, I have many many little dots (Cyan, Magenta and yello) on TA 300ci and TA 250ci befor 100 000 colors pages . I pull out drums but dots are on them. How can I solve it or prevent if it's necerry to change. I need help please. Thanks.
    • 22929
    Re: Copy quality problem on TA 300ci - 250ci
    Yes. We call those little lovelies "donut dots". If you look at them under magnification you'll see that they're tiny little donut shapes. They are actually areas of primary charge arcing to the drum. It's really hard to see the marks on the drum, but yes they are on the drum, and the only resolution is to replace the drum assembly. =^..^=
    • kaborwen
      • Feb 2010
      • 146
      Hi,
      Thanks blackcat4866.
      On the first machine, the "donuts" dots are noticeable, but not with second one. I want to know if changing main charge roller can stop arcing for the second machine. If there is service bulletin about it, i will be glad to get it.
      This attachment file is the status page for the first machine (TA-300ci)
      • Eric1968
        • 2458
        99.99% sure. Replace the drums like Blackcat says. Also update the firmware to the latest version and make all adjustments.
        • kaborwen
          • Feb 2010
          • 146
          Thanks all!
            • 22929
            Like Eric says, replacing the primary charge does stop the arcing. And the primary is included in the drum unit. =^..^=
