Help! Kyocera 520i Keeps jamming with jam code 60!
  • Techman1000
    • Dec 2010
    • 44
    I have a Kyocera 520i Keeps jamming with jam code 60, i've replced the vertical feed unit with a brand new one. can't seem to find anything wrong any ideas!
    • 23010
    Re: Help! Kyocera 520i Keeps jamming with jam code 60!
    I'd replace the duplex and pre-registration clutches. It's a known issue with this model. =^..^=
    • Venom
      Technical/IT Support
      • Nov 2009
      • 765
      agree, duplex clutch
      IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
      • Estico
        • Jun 2012
        • 21
        is it only jamming when feeding from tray 3, right? if yes, here is what you need to do - double the springs on the bottom left cover (from vertical conveying unit)
