Kyocera fs - 6025 no print when using adf but its ok when using platen glass
  • romnick
    • Aug 2008
    • 56
    Friends,I need your help,last month i installed this machine and today the customer is complaining that the machine is giving blank copy. i have tried to check the ADF by transferring it to another machine and it is working good, thats why i am concluded that problem is the base machine itself. Did any one encountered this problem already. Please reply!
  • Zackuth
    • Aug 2009
    • 448
    Re: Kyocera fs - 6025 no print when using adf but its ok when using platen glass
    You might want to look at the scanner lock. Some models will do that if the lock is not in the unlock position.
    If at first you don't succeed, redefine success
    • romnick
      • Aug 2008
      • 56
      sir, i checked already the lock and it is in unlock position, as i told before copying on platen glass is ok so it means that scanner is free.
      • Magicone
        • 16
        Does the scanner move to the left when you close the lid?
        If so.. do sim 411
        I am from canada, do not have that model but it looks like a TA-255
        • Zackuth
          • Aug 2009
          • 448
          I had a TA255 (like your machine) that copied from the glass, but from the dp was blank. The solution was the scanner lock. Just passing on a solution that helped me.
          • romnick
            • Aug 2008
            • 56
            You are right Zackuth the scanner lock is not unlock to the fullest, thank you and to all who gave ideas.Too much appreciated.
              • 22990
              Just came across that today on a CS-255c. I had a vague recollection of Zackuth's post. Thanks!
