Kyocera km 8030 optimizing performance troubles solution
  • jhon paulivan
    • Dec 2011
    • 18
    hai...........
    • 23008
    Re: Kyocera km 8030 optimizing performance troubles solution
    ... hmm. You don't say? =^..^=
    • habik
      • 2013
      Originally posted by jhon paulivan
      hai...........
      This post was here a while ago, need to do a better search !
      possible cause
      High heat within machine, machine is cooling down ...can take from 3-45 minutes depends on environment. Likely filters are dirty, not enough airflow, causing overheating and possibly jamming. Take all of them out (front/back/side) to see if it improves and then REPLACE them do not clean them, it will come back eventualy.
      Hope it helped
      Firmwares HERE
      • habik
        • 2013
        Yeah I missed that too Blackcat hope he says something now.
        Firmwares HERE
        • jhon paulivan
          • Dec 2011
          • 18
          engine always comes optimizing performane lies the problem where
          • jhon paulivan
            • Dec 2011
            • 18
            possible cause
            Hope it helped
            in addition to the fan problem?
            • JustManuals
              • Jan 2006
              • 9838
              Paul@justmanuals.com
              • umer_ml
                • Sep 2012
                • 24
                [QUOTE=jhon paulivan;310319]hai...........
                do heat secor hain aik waist bottle ke neechai hai aur doosra pichley cover ke upar uper waala sensor bypas ho jata hai.but how mail me.
                remove upper heat sensor.and plug a jumper of 1 k variable resistance .for more details mail me .umer_ml@hotmail.com
                • habik
                  • 2013
                  [QUOTE=umer_ml;310431]
                  hai...........
                  nice one!
                  Firmwares HERE
                  • umer_ml
                    • Sep 2012
                    • 24
                    hai...........
                    bypass the upper heat sensor with1 k veriable resistance and adjust veriable to the proper voltage
                    or mail me .
