JIMA1020@CHARTER.NET
  • JIMA1020
    • Sep 2012
    • 12
    I have a copystar cs300i. The machine will not count down when you ask for say 20 copies and machine should count down 20-19-18-etc. How do we program it to do so. Customer upset.
  • Kidaver
    Ghoulscout
    • Apr 2011
    • 912
    Re: JIMA1020@CHARTER.NET
    Press the job status/cancel button........if your customer is upset over such a trivial thing....best wishes to you....
    "In a cruel and evil world, being cynical can allow you to get some entertainment out of it."
    • JIMA1020
      • Sep 2012
      • 12
      i have never seen a machine that did not count down from the copy number requested. this is a large church that several users use. each department would like to know how many copies are to print before they, another user, can come back and copy their needs. thanks for your input.
      • nmfaxman
        • 1702
        Why not use the reserve feature?
        When 1 job is done, the next will start.
        • JIMA1020
          • Sep 2012
          • 12
          We can but cs2550, cs1635 and a number of other copystar equipment count down. I, along with my customer can believe the machine is so advanced but can't down count. Thanks for your input and any other suggestions will be appreciated.
          • Kidaver
            Ghoulscout
            • Apr 2011
            • 912
            You are describing everything the job status button tells you.....they can press the button and see how many jobs are lined up and how many left to go...I mean I know it's a pain in the ass to reach over and press a button....
              • 23010
              You can set the Status screen as the default screen, and set a short default time. Within say, 10 seconds, it can jump to the Status screen. I must agree with the others that this is a very trivial complaint. You're in for a hell of a ride ... =^..^=
              • Kidaver
                Ghoulscout
                • Apr 2011
                • 912
                And your comment on the machine being so advanced it doesn't do a count down is incorrect....it is more advanced as in the installed the Job Status screen which displays more information on jobs rather than just a countdown with older copiers....I have a nice machine in the print shop that has a status screen that shows the countdown and then breaks it down in a bar chart with times on jobs lined up..it's really neat and advanced...but I do have to push a button to view it...
                • JIMA1020
                  • Sep 2012
                  • 12
                  Originally posted by kidaver
                  and your comment on the machine being so advanced it doesn't do a count down is incorrect....it is more advanced as in the installed the job status screen which displays more information on jobs rather than just a countdown with older copiers....i have a nice machine in the print shop that has a status screen that shows the countdown and then breaks it down in a bar chart with times on jobs lined up..it's really neat and advanced...but i do have to push a button to view it...
                  i appreciate everyones input on the cs300i counting problem. I have advised the customer to use the job/status button and they are ok with the performance. Thanks to everyone.
