FS 1128 MFP C2000
  • Dr.silver
    • 38
    FS 1128 MFP C2000
    I am dying here. I am have problem with a 1128mfp it Bog downs you can hear it bog. and it get worse and worse. I cleaned all the Clutches, Cleaned the fuser and replaced the Motor. I need some help. I am not only having issues with this machine. I also have problem with the Printer models anyone know what I am over looking??
  • lees
    • Apr 2011
    • 95
    Re: FS 1128 MFP C2000
    Try looking at the drum. See if it is hard to turn or if the waste toner is full or hard in the unit. It could be causing the main motor to bog down. I haven't seen this problem on this model, but on some of the others, the drum will cause the motor to bog down causing the error code. Hope this helps. Let us know what you find.
    • Venom
      Technical/IT Support
      • Nov 2009
      • 765
      try to empty the waste toner out of the drum unit, have seen a few fill up and cause issues from noise to smudges
      IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
      • Dr.silver
        • 38
        Drum unit is moving nicely and I clean waste toner as well. Still Dragging and bogging up.
        • Kidaver
          Ghoulscout
          • Apr 2011
          • 912
          Are you using OEM toner? We've had a few machines that ended up with Katun toner in them....I'm sure I don't have to elaborate what a horrible idea that was....
          "In a cruel and evil world, being cynical can allow you to get some entertainment out of it."
          • Tonerkiller
            • Oct 2012
            • 668
            What was the solution? We have one with a c2000 code
            • JustManuals
              • Jan 2006
              • 9838
              Paul@justmanuals.com
              • zeeeba
                • Dec 2012
                • 58
                This picture shows what a service manual says about C2000 fault code.
                • Tonerkiller
                  • Oct 2012
                  • 668
                  Thanks, I know what the code means, just not sure where the drag is comming from
