fsc2126 fax
  • Kidaver
    Ghoulscout
    • Apr 2011
    • 912
    fsc2126 fax
    Had a customer call in with a FSC 2126 asking if the machine can be set up to only transmit faxes but not receive them. I'm not even sure this can be done or if there is some work around. I am going to call them back and get some more info on why and what sort of set up exactly they have, but anyone have any ideas?
    update..nevermind on this...we just set it to manual rx so it won't pick up
    "In a cruel and evil world, being cynical can allow you to get some entertainment out of it."
    • 23006
    Re: fsc2126 fax
    There you go. Simple problem, simple solution.
    If you didn't have that option you could just enable DRPD. The machine would look for a special ring, and none would arrive. =^..^=
    • Kidaver
      Ghoulscout
      • Apr 2011
      • 912
      Re: fsc2126 fax
      I'll keep that in mind...it's at a car dealership hooked up to their main line or something that customers call into alot....they only use the machine to send stuff out and wanted it off so if customers call in they don't get the lovely fax handshake signal....
