KyoceraMita KM-C2520, Maintenance mode, touch panel calibration.
  • Hansoon
    • Sep 2007
    • 3252
    Without having a machine available to verify I need to write up an instruction for non-techs how to calibrate the touch panel of the KM-C2520.
    According to the book it is:
    Press start button > Enter 10871087 on the keyboard > Select U201 with cursor up/down keys > Press center of upper left + > Press center of lower right + > Leave maintenance mode with Stop/Clear key.
    Is that correct the way I wrote it? To me it looks a little clunky.
    Is it the same procedure for all machines of the KM-C2520, 2525E, 3225, 3225E, 3232, C3232E, C4035E, C6030, C8030 series?
    Hans
    " Sent from my Intel 80286 using MS-DOS 2.0 "
    • 22601
    Re: KyoceraMita KM-C2520, Maintenance mode, touch panel calibration.
    Hans
    Two differences:
    1) start out in the Copy screen > 10871087 > ...
    2) ... > Press center of lower right + > Stop/Clear key > End > 001 (to exit service mode) > Start.
    ... and yes, applies to all Voyager, VoyagerE, and Harrier machines. It's all very similar op panel firmware. Indistinguishable. Most times it is totally unnecessary to perform the screen initialize. Typically it's close enough without doing the adjustment. =^..^=
    • Hansoon
      • Sep 2007
      • 3252
      Thanks Cat.
      Hans
