KM5050 regarding toner
  • goldencup
    • Nov 2008
    • 366
    Hi i would like to ask if the toner of KM 5035 can be used in KM 5050? Just the toner (powder) not the whole box. Thank you
    • 23010
    Re: KM5050 regarding toner
    The actual toner is the same. The cartridge has drive differences. =^..^=
    • Masterchief
      • Apr 2011
      • 280
      Transfering toner from one container to another can be a very messy job, If you are using non OEM toner than a plastic cap will be used as a seal when the toner is full to stop it leaking but if you use an Original then you will have to break the seal as these are glued.
      if you have to break the seal cap, how will you stop the toner leaking out all over the machine while its beeen used.
      sigpic
      • goldencup
        • Nov 2008
        • 366
        We have some few OEM KM5035 toners that wasn't used. Since they are the same, we're going to use it. We have modified toner box for KM5050 (no leak)
        Thank you very much.
