KM5050 C3300
  • goldencup
    • Nov 2008
    • 366
    [Error Code] KM5050 C3300
    Hi, have anyone of you encountered C3300 on KM5050? Lamp is okay. Before i go to CCD PWB and SHD PWB, is there any advise i should do, like do's and don't? By the way, how do you disassemble the SHD PWB from the machine Thank you very much.
  • Masterchief
    • Apr 2011
    • 280
    Re: KM5050 C3300
    I dont have my manuals with me but what does the code relate to, have you reset and tried to reboot the machine
    sigpic
      • 23008
      Re: KM5050 C3300
      I have literally never seen a blown lamp on a Kyocera Mita product. Ever since lamps changed from Halogen to Xenon or Fluorescent they never fail.
      But I have seen cases of false C3200 and C3310 codes as a result of poor quality power, especially overloaded circuits. What it comes down to is that the lamp just does not light quickly enough or brightly enough. I'd set up the Power Quality Analyzer, and see just how crappy the power is. Overloaded circuits show as high ground to neutral values (anything over 0.5vac is too much). In the cases I've seen ground to neutral was 4.0vac to 35.0vac.
      Note: just hooking up your meter for 5 minutes to 1 hour will not give you an accurate picture. You really need the PQA, and for a 48 hour period. =^..^=
        • 23008
        Re: KM5050 C3300
        C3300
        CCD AGC Problem. After AGC correct input is not obtained at the CCD. 1) Reseat connectors @ SHD PWB & CCD PWB, 2) Pinout harnass, 3) Repl lamp & inverter PWB, 4) Repl SHD PWB, 5) Repl CCD PWB.
        C3310
        CIS AGC Problem. After AGC correct input is not obtained at the CIS. 1) Repl DP inverter PWB, 2) Repl CIS, 3) Repl DP Main PWB.
        Oh, and don't touch the CCD or SHD PWB. There is probably nothing wrong with them, and by removing them you'll probably unfocus the optics.
        • rashid120
          • Jun 2010
          • 76
          Re: KM5050 C3300
          i encountered same problem C-3300.....please change the exposure Lamp....even it looks good...replace it....your problem will be solved.
          Thanks and Regards.
          Rashid Iqbal
          • goldencup
            • Nov 2008
            • 366
            Re: KM5050 C3300
            Thanks for all your help. Problem solved. Our guy here replaced the top glass because it was broken, they took a glass from a different machine (KM3530) which they thought it is the same. At first look yes they are, but the WHITE "whatchamacallit" under the the glass is different causing C3300 to appear.
            • banginbishop
              grumpy old git
              • Oct 2007
              • 894
              Re: KM5050 C3300
              good to know you fixed it
              i've had to replace a lamp (blown), also had a lamp covered in dust and the underside of the glass dirty to give these errors
              Incontinentia Buttocks
              • ES-OGT
                • Aug 2011
                • 129
                Re: KM5050 C3300
                Just an FYI on this code. We've actually had that code come up on a machine in a REALLY filthy environment. Blew some air on the CCD sensor (really lightly and I don't recommend canned air). Problem went away.
                • redzventures
                  Service Tech
                  • May 2009
                  • 45
                  Re: KM5050 C3300
                  All these comments were very helpful as I have to look at a KM5050 in the morning with this very code. Of course, I would have looked up the code and had a think but using sites like this in advance of going to a call can speed up things as all of our experiences can really shed light on things. I'll come back to you after my first call to let you know what I did.
                  Later
