Copy star 2550 blank copies when using doc feeder
  • hockeyguy
    • Mar 2010
    • 6
    [CQ] Copy star 2550 blank copies when using doc feeder
    I have a copystar 2550 giving blank copies when you use the doc feeder.Under glass,prints,faxes all come out fine.
    Did memory clear reinstalled adf harness, scanner is moving to home
    Postion . Any ideas thanks .Paper is face up feeder
  • JustManuals
    • Jan 2006
    • 9838
    Re: Copy star 2550 blank copies when using doc feeder
    Paul@justmanuals.com
    • r3d343420
      • Aug 2012
      • 59
      Is it completley blank? I have seen the mirror for the doc feed oxidize from heat causing the copy to come out very faded, close to blank.
      • hockeyguy
        • Mar 2010
        • 6
        yes it is completley blank.
        • Dan J
          • Oct 2011
          • 25
          I've never seen this problem on a 2550, but in the past this scenario has always involved the optics ribbon cable. Particularly where it flexes as the mirrors move. Maybe even the inverter PCB.
          • madas
            • Aug 2008
            • 313
            Does the scanner carridge move to the correct postion, ie, nothing obstructing it's path?
            it sounds like a sort of problem i saw with a scanner lock on (different model).
            madas
            • Masterchief
              • Apr 2011
              • 280
              wha happens when you put a copy in the doc feeder posistion and leave the doc feeder open, hold down the sensor and try do a sky shot copy.
              Have you tried the auto settings in service mode???
              sigpic
              • hockeyguy
                • Mar 2010
                • 6
                Hey guys thanks for the help . There was something blocking the scanner on the rear side . Removed it.did a dp position adj. works fine.
