Scanning to Printer
  • colin
    IT
    • Sep 2010
    • 38
    [Misc] Scanning to Printer
    I am trying to scan from a black and white 4500i to a small HP network laser printer. I have setup the destination in the address book using the following;
    __________________
    FTP
    Hostname: 192.168.1.15 (HP IP)
    Port:9100
    Username: lt1, LT1, LTT1, ltt1
    Anything you guys see I am missing? Wrong username?
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1897
    Re: Scanning to Printer
    Did you try it without any username ?
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
    • nmfaxman
      • 1702
      Why are you trying to scan to a printer?
      Printers print, scanners scan
      WTF?????????????
      • tmaged
        • Oct 2008
        • 1897
        Because you can color scan directly to a color printer from a mono MFP. And it's geeky !
        Hope that helps !
        -Tony
        www.dtios.com
        • colin
          IT
          • Sep 2010
          • 38
          I did try it without a username, no go.
          • tmaged
            • Oct 2008
            • 1897
            What error code did you get ? That should give you a hint of what direction to go.
            Hope that helps !
            -Tony
            www.dtios.com
            • colin
              IT
              • Sep 2010
              • 38
              No error code, the MFP blinks memory and eventually stops... and nothing out of the printer. Kyocera support says it depends on what machine you are sending the scan to, in this case it was an HP. I don't think that is the problem though. That printer does not know that the image being sent to it is coming from a copier/scanner. It just sees raw data coming across on port 9100. So i don't know. I have given up.
              I also tried sending on port 21 as Kyocera recommended. Nothing. Interestingly enough when running the "Test" to test the connection it just cycles over and over... never comes up with an error or "successful".
              • Venom
                Technical/IT Support
                • Nov 2009
                • 765
                does the hp have pdf direct print availability? you should be able to create a folder on a pc and drag pdf into it and see if that prints...is so then scan to that folder from the kyocera
                IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
