prt. num. needed
  • dj_pilotkid
    prt. num. needed
    taskalfa 250ci transferbelt sensor
    • 22999
    Re: prt. num. needed
    A sensor within the transfer belt assembly? That sells as a unit only. I would have no way of confirming what sensor would match. =^..^=
    • nmfaxman
      • 1702
      Unless the sensor has really long diodes on it, a sensor is a sensor.
      Check if it is negative switching or positive switching.
      All the manufactures buy sensors from a sensor factory.
      I have put Minolta sensor in a Canon and a Ricoh, no problem.
        • 22999
        Why do you want this sensor? What code? I could possibly scare up a used unit somewhere for parts ... =^..^=
