cs 250ci quality
  • User Name
    Awesome Sauce
    • Nov 2009
    • 405
    cs 250ci quality
    have a 250ci with 100k, copy/ prints are faded , not in optics, are these lasting full pm (pm 300k) or do we need drums
    Just because you're not paranoid doesn't mean they're not out to get you.
    O.o
    WARNING: My profile page can cause blindness in small children and old copier techs. View at your own risk.
  • Dave10
    • Jul 2008
    • 197
    Re: cs 250ci quality
    When this happens to me, I run all the refresh modes. Drum refresh, developer refresh, gray adjust, even, sometimes, AC calibration. It usually works.
    • Jude
      • Oct 2009
      • 256
      Yes works for me!
        • 23009
        Once you've done a calibration print off the U089 Gray test patterns in each base color. This is the best way to identify primary charge or drum problems. Watch for repeating patterns (38mm: primary charge; 49mm: cleaning roller; 96mm: drum, 177mm transfer belt). If you catch it early enough a changing a primary charge roller will preventatively save the drum. If you arrive to the donut dots (primary charge arcing) it's too late for that drum.
        Once you've replaced parts calibrate again. =^..^=
        • User Name
          Awesome Sauce
          • Nov 2009
          • 405
          The Gray Adj. seems to have done the trick. Thanks!
          Originally posted by Jude
          Yes works for me!
          Me too!
          No repeating patterns that I could see. The copies and prints were just a bit washed out. The Gray Adj. seems to have resolved this for now. Black still seems a tad off but the customer is happy so we'll see what happens. Thanks for the advice!
          O.o
