Changed out the engine PWB under the scanner and got this code after I did the job. Been hunting connectors and checking pins. 2 Hours and cannot find the problem anywhere. Anyone have any ideas ?
Kyocera 2525e, C2201 After changing Engine PWB...
Tags: None
Re: Kyocera 2525e, C2201 After changing Engine PWB...
Was the engine PWB new? Is it possible that you introduced the problem with the replacement PWB?
1) Run sim U030 (conveying motor) to check for drive problems, 2) Reseat YC1 @ motor relay PWB and motor connector, 3) Repl drum motor BK, 4) Repl motor relay PWB, 5) Repl engine PWB.
=^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^= -
Have not seen this machine yet. Just thinking, if you changing PWB there is usually data stored for that machine, is there a ROM you may be looking for the swap from the old boar to put in the new one?Comment
Paul@justmanuals.comComment
It's just the slowest version of the VoyagerE. When you swap in the original code DIMM all the machine data stays with the machine.
Oh! I see what you mean. Is this the original code DIMM? =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^=Comment
The code turned out to be the Black drum motor, I switched the motors with an known good motor and got a different code. Looks to me like (For whatever reason) the new engin PWB fried the motor. I asked a Kyocera tech that works here local, and he said their was an upgrade to the motors and that was probably a bad one...Comment
Got the board from Hytec and all the chips were installed...Comment
