recycle toner 6030
  • umer_ml
    • Sep 2012
    • 24
    recycle toner 6030
    what happen that i use waste toner in 6030?
    • 23009
    Re: recycle toner 6030
    You're copy quality will get progressively crappier, and undertoned.
    Most manufacturers do not recycle mono-component toner because paper dust and room lint collected from the cleaning unit don't work very well to produce black images on paper. The toner portion of this mixture gradually decreases as it's consumed, since the foreign matter never leaves the developing unit. And the larger particles of foreign matter will collect under the S-blade creating light lines or void areas in the feed direction. Dual component toner systems better tolerate small amounts of foreign matter in the developer and have a slightly greater doctor blade gap, allowing more of those large contaminants to pass the doctor blade unobstructed.
    But if you don't mind really poor copy quality go ahead, enjoy yourself. The only real harm is having to go back and vacuum out all that contaminated toner, installing new toner and running U130.
    For the record, I'm not a fan of recycling on mono-component or dual component toner systems. Pure clean toner always produces better images than contaminated toner.
