Kyocera mita 6030 black copy
  • selmila
    • Aug 2012
    • 133
    hi i am getting black copy in my Kyocera mita 6030 MFP. i have checked the connections and the lamp area but unable recover the problem.any help?
  • Kidaver
    Ghoulscout
    • Apr 2011
    • 912
    Re: Kyocera mita 6030 black copy
    Are your internal prints coming out fine?
    "In a cruel and evil world, being cynical can allow you to get some entertainment out of it."
    • selmila
      • Aug 2012
      • 133
      yes print is good.
        • 22930
        It's not impossible to have a bad lamp, just very unlikely. My machines had 3M prints and more, and never replaced the lamp.
        Does it come on? I'd also check the lamp harness (the one that flexes), and the inverter. =^..^=
        • extreme
          If your'e using the DP and you will be able get a black copy, your problem is in your DP calibration, and if even to your platten, try to
          calibrate using the designated charts and programs provided by kyocera.
          • vasie nair
            If only your Scan and coping is black and printing is fine then your main PCB is gone faulty.
            Regards
            Vasie Nair
