Jam 4701, 4702, etc... on TASKalfa 6500i
  • Jules Winfield
    • Jul 2009
    • 821
    [Jamming] Jam 4701, 4702, etc... on TASKalfa 6500i
    I keep getting jam 470x (depending on which drawer I'm using) whenever duplex is selected. The paper makes it through the fuser, but then gets folded up in the switchback section. I've tried swapping out the entire switchback section with one from another machine just as a test, but there has been no change. Firmware was updated (and then downgraded to see if the machine behaved any differently), but this had no effect. Does anyone have any ideas as to what could be causing this issue? Any help would be greatly appreciated.
    But I'm trying, Ringo. I'm trying real hard... to be the Shepherd.
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1889
    Re: Jam 4701, 4702, etc... on TASKalfa 6500i
    Is it the duplex gate binding up as it does on the slower units ?
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
    • madas
      • Aug 2008
      • 313
      Hi, Not your exact model but may help.
      madas
      • Jules Winfield
        • Jul 2009
        • 821
        It doesn't appear to be, but both the switchback unit and eject unit have been swapped out to test and so far no change...
        • lukas
          • 1
          same problem any ideas?
          • ccfc87
            • Feb 2014
            • 18
            Same problem but on ta8001i. Had a new Switchback unit a few weeks back.
            Has also had bridge sensor actuators as they had gone flat.
