KM-5050 DRUM
  • mrfuser
    • 1617
    KM-5050 DRUM
    Does anyone know if there is a rebuild kit for the KM-5050 drum unit? What a waste having to buy a PM kit everytime we have to replace just a drum for clients!
    Kelly
  • Max
    • Oct 2011
    • 555
    Re: KM-5050 DRUM
    You can buy just the drum unit its just expensive. As long as you clean the filters on regular basis,paper dust collectors and the grid the drum will last 500k plus no problem at all.Don't forget KM toner.It is when the paper dust collectors is over flowing and it gets in to dev unit and the surface of the drum then you will be lucky if it lasts 200 k. Also vac out the transfer roller now and then.
