CS-2550 Scan to PC
  • monstott2010
    • May 2025
    CS-2550 Scan to PC
    I have set up many of these with little to no problems so this one is really cranking my tractor... Configured the scanner file utility, checked firewall settings, everything just as normal, test ok... go to demonstrate to user, connection to pc failure, recheck settings, no help. Delete everything and start over... initial test ok, second test failure again....
    Initial thought may have been to fact that user has wifi and lan connections going so disabled wifi but did not help (scan on lan connection). Recommended user swap out switch but not sure what else can cause initial connection to flow ok only to fail on second connection.... I did check for IP conflicts as well but found nothing to indicate a problem there.
  • luis8832
    • Dec 2008
    • 250
    Re: CS-2550 Scan to PC
    Did you check for a firewall? Or is the client running an anti-virus with a firewall. If they are you gotta give the exception.
    • JR2ALTA
      • Feb 2010
      • 2028
      Can you ping the IP from another computer, a failure would suggest anti virus or port issue
      • kkendric
        • 301
        IP conflict?
