Kyocera fs1118 showing cf2ff error.
  • aoulia
    • Jul 2025
    [Error Code] Kyocera fs1118 showing cf2ff error.
    can wereplace the transistor LMS1587?
    • 23008
    Re: Kyocera fs1118 showing cf2ff error.
    Cf2FF:
    An error is detected at the Network control section.
    1) Reformat HDD U024 FULL; 2) Initialize backup memory U021; 3) Repl main PWB; 4) Retrieve USBLOG and contact SAD (or retrieve packet capture data depending on the results of analysis)
    So where did you get his stuff about transistor LMS1587? And if you find it, what are you going to do about it? The components on the main PWB are too small for you to do any repairs.
    In situations like this, even when I can identify a bad component, what next? You can't fix it. =^..^=
    • Has Been
      • Nov 2012
      • 48
      Update the firmware
      • JustManuals
        • Jan 2006
        • 9838
        Paul@justmanuals.com
