TA 300Ci ..Command Center Strange one ..
  • Geo
    • 662
    Hi all.
    Have a TA 300ci with a fax unit. Customer unplugged the copier while in self dig process. The box is working normally except.......
    The address book disappeared and this is the strange part. I reentered the addresses and.. Everything works in command center, except when trying to set the fax fw function ..the fax fw page is blank.
    I did a mm 21,24,600,601 and reloaded the firmware.No change.
    Has anybody seen this before...any thoughts..
    • 23008
    Re: TA 300Ci ..Command Center Strange one ..
    No, never, but ... what I would do is remove the fax and re-load firmware. Power Off, re-install fax, re-load firmware again.
    It's saved me in some strange fax situations. =^..^=
    • Geo
      • 662
      Blackcat ....
      Thanks.. excellent idea...didn't think of removing the fax . ...But , just for kicks , I will try to load the page after removing the fax,but before reloading the firmware.
      Will post the results of the solution (I hope).
      Geo
      • Venom
        Technical/IT Support
        • Nov 2009
        • 765
        I suspect the fax dimm is faulty
        IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
