Kyocera Taskalfa 820 with PF-660 Large Capacity Side Feeder Double Feed Problem
  • copier-jockey
    [Misc] Kyocera Taskalfa 820 with PF-660 Large Capacity Side Feeder Double Feed Problem
    When I run letter sized sheets from the side feeder, I will get about 6-12 pairs of sheets in a row (out of a few thousand) that double feed from the side feeder, get printed and duplexed all while staying together, and they exit the delivery as one sheet.
    After printing and post processing, we find these sheets that ran through together where each one only got printed on one side.
    Our technician is baffled and nobody seems to know how to fix it or how it's even possible. Hope someone can help?
  • madas
    • Aug 2008
    • 313
    Re: Kyocera Taskalfa 820 with PF-660 Large Capacity Side Feeder Double Feed Problem
    check for damaged paper, ie. edges of the ream scratched and pinched together. and try a brand new ream in case it is somehow damp paper which was in the m/c already and new stuff put on top.
    madas
      • 23008
      madas
      I agree with madas. There are only two possible causes:
      1) Paper: try riffling, or switching brands. When the paper manufacturers cutters get dull, the cutting process can weld the edges together. I've seen whole reams that stayed together like the ream was glue-bound.
      2) Rollers: These feed rollers are supposed to last 500K, but a more realistic expectation is 300K pages. Be sure to include pickup, feed, and separation rollers. I've assembled a one-way bearing kit for replacement at 1M pages.
      • tech07
        • Aug 2008
        • 409
        Agree with Blackcat. Worked on one last week with similar symptoms. Not only were the feed tires and sep pully worn, the torque limiter had a large crack in it, allowing multifeeding. PS Agree about the paper too.
