CS-2050 fax option
  • skibum
    Independent Service Tech
    • 234
    [Electrical] CS-2050 fax option
    I have a CS-2050 that the fax stopped working and I have uninstalled and reseated all the fax components and had it running for months then it has came back now with the same problem. Does anyone have this option new or used for sale. There is no code. The problem is when dialing it does not respond even when using hook and listening the tones for each number sound very distorted.
    Thanks in advance.
    • 23010
    Re: CS-2050 fax option
    I've successfully reseated YC2 on the occasion that I saw something similar. Sorry I don't have a fax kit, and they're not cheap. =^..^=
    • skibum
      • 234
      Thanks Black Cat
      • MR Bill
        • 532
        I have had 2 problems with those fax systems. One was a fax board in the back of machine and the other problem was the op panel. I always like to have a parts machine for trouble shooting. I will sell you a fax systems for $200 if interested.
