KM-C4035E Harddrve
  • EDSNOW
    • 180
    [Misc] KM-C4035E Harddrve
    I wanted to ask if anyone has used another generic hard drive as a replacement for the OEM unit?
    In my case I am trying an identical harddrive at a lot less cost without any success.
    I am considering the main board might be the problem.
    The existing drive had issues in the past and formatting resolved but not this time.
    Kyocera support indicated that this is a proprietary harddrive but I don't think that this is correct.
    I am not aware of any special procedures when installing other than a format through the M-mode.
    I expect I will try the drive in a known good operating machine.
    Thanks for any input.
    • 22999
    Re: KM-C4035E Harddrve
    I've subbed the exact same HDD: Toshiba HDD2D10 40GB 5400RPM 2.5in HDD
    then formatted it from the service mode. It works fine. =^..^=
    • EDSNOW
      • 180
      Thanks Blackcat
      I quite agree, it appears that the issue may very well be something other than the drive.
      I will update with the resolution at a later date.
      I appreciate the response.
      • kkendric
        • 301
        You should be able to replace either HDD with a Compatable Drive. The main HDD is a 3.5 inch IDE and their can be an optional drive for the control box(Printer section. If the machine has disabled the main disk drive you may have to perform a U906 to reenable this drive.
        • kkendric
          • 301
          I forgot the optional drive is a 2.5 inch ide drive.
          • Venom
            Technical/IT Support
            • Nov 2009
            • 765
            I thought they were proprietary and only the toshiba will work....and I don't think toshiba doesn't makes them anymore. Many of the hard drives can be reformatted on a PC and reused, some can't be saved.
            IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
            • EDSNOW
              • 180
              F Y I
              I am waiting on a main pcb and will advise the outcome.
              • EDSNOW
                • 180
                Problem resolved.
                Both harddrive and main pcb had to be changed.
                Hope this may helpm others.
                ED
