copystar cs-c3225E possible eprom switched
  • Kirk
    • Apr 2011
    • 16
    Hello all,
    I was wondering if anyone knew of a way to find out if which machine an eprom belonged too. We have 3 machines that parts were swapped off of and now when we try to get them running we were getting 0210 codes and 0220 codes.
    thanks
    kirk
  • Zackuth
    • Aug 2009
    • 448
    Re: copystar cs-c3225E possible eprom switched
    The codes you are getting are communication between boards errors. I'd first make sure the connectors are all connected tightly. If the ribbon cables are not just right, they'll pop a code--I know.
    If at first you don't succeed, redefine success
      • 23007
      It does matter which eeprom came from which machine. The serial number is written in there somewhere, but I know no way of tell which is which, without just physically trying all the possibilities.
      3 chips means 9 total possible solutions. =^..^=
      • Kirk
        • Apr 2011
        • 16
        ok I am mainly using just the eprom on the engine and main with no print board. i was able to get the machine up and going with a copy count of like 67 million. when i try different eproms i either get c0100 c0150 or c0180 codes. can anyone please advise what to check next?
        Kirk
          • 23007
          Originally posted by Kirk
          ... i was able to get the machine up and going with a copy count of like 67 million...
          So you got it working. Great. =^..^=
          • Kirk
            • Apr 2011
            • 16
            ok i have some matching pairs that i keep getting a c0180 code. does this mean the main board is bad or the eproms are still not right?
              • 23007
              From what I'm reading, the main PWB is most likely.
              When in doubt go by cost. The EEPROM is much cheaper than the main PWB. =^..^=
              • taskalfaman
                • Nov 2009
                • 137
                hi,
                try to do sim 004, it can help. no guarantee.
                • Kirk
                  • Apr 2011
                  • 16
                  In running in maintence mode 04 i have been able to get machine model numbers off of some of the eproms. does anyone know what information is stored on the main and engine eprom?
                  Kirk
