kyocera 6025 showing error6050 intermitentily
  • vj200729
    print mate
    • 81
    kyocera 6025 showing error6050 intermitentily.i have cleaned thermister ,but problem repeats on taking copies intermitentily. pls respond if any sujjetions.
    • 22930
    Re: kyocera 6025 showing error6050 intermitentily
    Have you done anything? =^..^=
    • vj200729
      print mate
      • 81
      sir ihave cleaned fixing unit thermistor
        • 22930
        Originally posted by vj200729
        sir, I have cleaned fixing unit thermistor
        ... and reset the fuser error, sure. And I'm assuming you get some prints until the code returns. Maybe it's time to replace something, like the thermistor. Sorry, I don't know if this fuser comes as an assembly or if you can get a separate thermistor.
        Another possibility is that your fuser codes are caused by recent power events. Usually I'll ask the enduser if they've had a power outage or brownout recently. And did it correspond with the occurrence of the code.
