Kyocera Mits KM-4035
  • tcypy1961
    • 773
    This problem I am about to explain only happens when I duplex. The backside of the duplex copy comes out faded every time. However, if I just run single sided copies and put them back in the tray to run the backside this does not happen. A new maintenance kit was just put in but I am not sure if this problem was present before it was put in. Another thing, it looks like a copy with a poor transfer or under-toned. Thank you for any help provided.
  • Venom
    Technical/IT Support
    • Nov 2009
    • 765
    Re: Kyocera Mits KM-4035
    I would look at the transfer roller springs and contacts
    IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
      • 23009
      You beat me to it. See if the front spring is missing. Also check for J60 jams. =^..^=
      • Geo
        • 662
        Try setting U956 to old type of paper conveying unit, I have had good sucess by keeping the setting to "old type" even with "new type ".
        Have fun..
        • finni72
          • Jul 2010
          • 25
          Just try to clean the transferroller with a dry cloth.
          I guess it just dirty.
