TaskAlfa520i - creasing paper
  • daveh12
    • Jul 2012
    • 157
    hi,
    i have a problem with a TA520i creasing paper in the fusing unit, causing it to jam. 500K on the machine, new fusing unit installed. seems to be happening mostly on double-sided.
    All cassette pick-up rollers are new, guides correctly seated, duplex unit clutch changed but still problem persists. Its not all the time, couple of times every 100 copies approx. ive ruled out any issues with the paper and firmware is up to date.
    Any ideas will be greatly appreciated?
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5007
    Re: TaskAlfa520i - creasing paper
    Do you have creasing issue also with old fuser?
    • madas
      • Aug 2008
      • 313
      Hi, I would suggest if you have another fuser to try that 1st, quick and simple elimination of the fuser.
      if it is not the fuser then is it tray specific or all trays? you say mostly on duplex, is the customers m/c set up to duplex every thing even single sided? ours is. I see you have ruled out the paper but have you tried a new ream of paper that you have opened and put in yourself to eliminate any possible misaligned paper mid stack?
      just a couple of thoughts on the problem and being random is a pain.
      please post the fix
      madas
        • 22999
        How about media settings? If you feed ledger 20# bond on heavy paper settings it will wrinkle, regardless of the paper condition. =^..^=
        • Venom
          Technical/IT Support
          • Nov 2009
          • 765
          Sometimes creasing can be caused by the LCT trays not level or paper being bent when installed in tray. Try a different paper tray as a test.
          IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
          • daveh12
            • Jul 2012
            • 157
            Problem was originally happening with the old fuser, then it was replaced, it happens from all trays, and I have loaded fresh reams of paper myself. Its set up for single-sided, happens mostly on duplex but does occur on single- sided also.
            • Kidaver
              Ghoulscout
              • Apr 2011
              • 912
              Look on the duplexer unit just above the transfer roller there is an adhesive sheet there. Called a conveying sheet and cost about 4.50. I have seen 2 machines so far where about 2/3 of the way along towards the back it starts to bubble up and snag paper. This might be your issue...might not. Wouldn't hurt to check it tho.
              "In a cruel and evil world, being cynical can allow you to get some entertainment out of it."
              • daveh12
                • Jul 2012
                • 157
                I've seen this before but it is fine on this machine also.
                • jmaister
                  certified scrub
                  • Aug 2010
                  • 755
                  what's the meter count on the machine?
                  Given its not the fuser. (not ruling it out)
                  creasing can be due to uneven spring pressure(exerting on the white rollers). Or or the springs on the hooks to latch the panel has become weak.
                  swap out duplex assembly? Where is the paper source? if its cassette 2, i'd check the side panel as well
                  is the image skewed? is there any nic mark on the edge of the paper?
                  Idling colour developers are not healthy developers.
